hi opened up a new pack of ritekg05 today tried twice ,got bad artifacts about 7mins into disc play ,was using shrink 3.2 and burnt with nero using same ,however when i burnt using nero to burn separate from shrink no problem at all just a flook?
ah might have the answer last batch of discs ritekg04 these g05 been bumped
Maybe a fluke. DVD SHrink uses the Nero engone and should produce identical results. BUT,,, if you get good burns by burnign separately with Nero rather than thgrough Shrink then what can I say!! It's just one of those weird misteries of burning. I been successfully using Shrink to ISO and burn with Decrypter. Works perfect all the time.
No DVD can withstand the power of DVDShrink along with AnyDVD!
Made On Demand discs - bad burns
By oldfart13 in forum DVD RippingReplies: 5Last Post: 12th Aug 2011, 14:45 -
Keep getting bad DVD burns after OS reinstall
By brassplyer in forum ComputerReplies: 18Last Post: 20th Sep 2009, 02:12 -
Toshiba RD-XS35 producing a relatively high amount of bad/weird burns
By Bix in forum DVD & Blu-ray RecordersReplies: 14Last Post: 23rd Sep 2008, 12:25 -
Bad burns
By jalfirov in forum Newbie / General discussionsReplies: 7Last Post: 17th Aug 2007, 14:14 -
Bad Burns
By jalfirov in forum Authoring (DVD)Replies: 1Last Post: 16th Aug 2007, 04:23
