Problem burning vcd with easy cd creator 5..I burn the vcd and it burns perfect and then when I goto play it with twins video player or I-video cd player it won't play..its getting me mad because i've tried all day yesterday and today and i've lost 15 cd's and its getting me mad..please help..if you know any software that make them can you please tell me and i've tried with nero to and it does the same..and yes they are mpg files..
Please Help
Thanx,
Joey -
CD Creator 5 does has a nasty bug in VCD creator that prevents it's VCD from playing on some standalone players.
Give up on that one.
Nero should not have that problem, which leaves a few possibilities:
1. your player cannot read the media you are using.
try different media, try CDRW media
or replace your hardware player
2. Your mpeg stream is not VCD compliant
The VCD creation apps you are using should warn you if this is the case, but they often are not strict enough.
3. You are not using the software correctly
Read the documentation that came with your software. Make sure you are creating a VideoCD, and not just burning the mpg file onto a data cd.
Go to the tools section here, download the full version of VCDEasy, extract to a directory and run it.
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 14:26 -
Easy DVD Creator by Ether Software
By DW49 in forum Authoring (DVD)Replies: 4Last Post: 30th Dec 2007, 14:33 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 15:27 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 12:10 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 15:27
