Okay, I got a ADVC-300 here, and noticed it has a switch for Chroma Filter. You can set it to 1.3MHz or 2.0MHz. What the heck is the difference? The manual does not explain it.
From the Canopus forum -
Chroma-Filter:
It can change the frequency characteristic of the color ingredient for the output analog signal. There are 2 settings, 1.3MHz and 2.0MHz.
Normally, the 1.3MHz provides enough good subjectively quality for the output analog video signal for most of the nature image.
If the source signal has a high frequency characteristic of the color ingredient, the 2.0MHz setting will reproduce the source signal into the analog output faithfully. Sometime, there is a bit influence of the aliasing on it.He's a liar and a murderer, and I say that with all due respect.
Canopus ADVC 300 DVD Capture Now?
By Detta in forum Capturing and VCRReplies: 7Last Post: 20th Sep 2011, 14:02 -
Capturing with canopus advc 300
By blacksheepdownunder in forum Newbie / General discussionsReplies: 1Last Post: 19th Jul 2010, 09:20 -
canopus advc 300 macbook pro
By petoo2 in forum Video ConversionReplies: 0Last Post: 9th Dec 2009, 20:29 -
Need help in choosing a VCR to be used with a Canopus ADVC-300
By teslaprofile in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2009, 23:31 -
Canopus ADVC 300: best settings / tweaks ?
By fabweb in forum Capturing and VCRReplies: 3Last Post: 12th Sep 2007, 07:34
