I have two issues with this program, first when I try to synchronize the subtitles with the movie, I can only open the first vob files i.e. VTS_01_1, and do the adjustment, and by opening the next segment, the timer starts from zero, which renders the method of subtitle synchronization with first/last spoken line of the movie impossible for example subtitle 49:00 with the relevant movie segment which is a part of VTS_01_2. Second and most important, during the preview, if I go forward and backward, it will cause a time mismatch, i.e. starting the preview from beginning of the movie, the timer shows the correct corresponding time, forwarding the movie and the timer lags behind the original time, it shows 9:30:256, but it is actually 9:35:456, which also makes the adjustment impossible.
Any suggestion is highly appreciated.
i don't think subtitle workshop is designed to read dvd/vob files that well. you could use dvd2avi and open all vts_01_1-x vobs and then save as project, convert the project file to an "fake" avi with vfapi reader. last try open the fake avi in subtitle workshop...i have never tried that though.
Subtitle workshop, rewinding problem
By ~Fly in forum SubtitleReplies: 5Last Post: 13th Mar 2012, 12:36 -
Frustrating Problem! Subtitle Workshop Won't Play Videos, Noticeably, AVIs!
By justforthis,maybe in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jan 2012, 06:12 -
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 03:09 -
Subtitle Workshop Overlapping Problem
By BradlyB in forum SubtitleReplies: 4Last Post: 11th Feb 2009, 20:37 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 22:16
