I have read and searched through countless guides to convert avi files downloaded from shadowrealm into dvd format. I tried using winavi and converting that way then burning with Nero. However when I insert the dvd in the player it wont play it and in a ps2 it says invalid format.
All of the files have the following information using avicodec:
File : 495 MB (495 MB), duration: 1:34:45, type: AVI, 1 audio stream(s), quality: 36 %
Video : 409 MB, 603 Kbps, 24.0 fps, 480*212 (2.21:1), MP43 = MS MPEG4 V3, Supported
Audio : 86 MB, 128 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
What can I do?
I am using a I/O Magic 12x dvd writer with memorex dvd+r disks..I know the disks will play in my dvd player from past experience.
Please help me out if any of you can!
Results 1 to 9 of 9
how do you burn with nero? do you choose dvd-video? what version of nero?
You'll have to convert the AVI to MPEG2 using a program like TMPGenc. Then author and burn the MPEG2 using a prog like TMPGenc DVD Author or DVDLab.
This process has been covered extensively in guides...
ie:
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=AVI+to+DVD&h...or+List+GuidesThe distance between genius and insanity is measured only by success... -
Yeah, I would check your output settings. You should have a couple folders, VIDEO_TS and AUDIO_TS and a bunch of .vob and .ifo files in your VIDEO_TS folder. If you want to try another encoder I would recommend TMPGENC or The Film Machine. Then use GUI for DVD Author to author your dvd. Then make a data dvd in Nero and drop the outputted VIDEO_TS and AUDIO_TS folders from GUI for DVD Author, and you got it!
trickyman...when i do that...tmpgenc crashes...it locks up.I have tried the download again and restarted it again...but it just crashes.
Nero smartstart is what came with my dvd writer....nero express 6 boots up to nero smartstart..
Is there any problem with loading a 24.00 fps avi file in winavi?
Should I use winavi setup as ntsc or pal?
If it starts as a 24fps file what will converting to ntsc or pal do to it?
Just use winavi then burn with nero smartstart version 6 or is there something better? I am using win98SE by the way -
trickyman...when i do that...tmpgenc crashes...it locks up.I have tried the download again and restarted it again...but it just crashes.The distance between genius and insanity is measured only by success...
As far as TMPGENC, that sounds like a codec problem. You could try another encoding program, like BBMPEG, to make sure. -
I now have no trouble making a dvd from an avi file. I have solved that dillemma with everyone's help from here. thanks again!
However I have dvd files created with winavi that I want to join to put 2 movies on one dvd. The trouble I have is that the files that winavi converts to is NOT the same files as a dvd rip would be. So with tmpegnc dvd author or reauthoring with dvd shrink I cant open the files because they are NOT true dvd ripped files.
Any suggestions??
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
