  1. Member geohei's Avatar
    May 2002
    Luxembourg
    Hi.
    I'm looking for a Premiere Pro plug-in which is able to create face blurring (to blur a moving target in a video stream). There are methods to do it inside Premiere pro, but all this is twisting (but it works!).
    Is there no plug-in around (like Boris ...) which is able to do that?
    TIA
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    if you want autotracking - you will have to use another product instead of premiere -- otherwise just do it by hand with keyframes
  3. Member geohei's Avatar
    May 2002
    Luxembourg
    - What do you call "autotracking"?
    - Which other product would this be?
    TIA
