hi all i am using win avi video convertor to convert xvid movie so i can burn to dvd this works great but sometimes i get a movie in 2 parts how do i join these or how do i add the 2 together so i can burn to dvd.
is there a menu program i can use
thanks
steve
Hi stevehickey6,
The above are 2 options, though joining AVIs with VirtualDub (called "appending") requires that the framerates of each file are exactly the same - I once had a problem coz one file was 24.9996 fps and the other was 24.9993 fps.
Or, you could just go ahead and encode them to MPEG and then use the two separate files as inputs during authoring. The output VOBs will treat them as one contiouous file.
I've not used Womble (MPEG-VCR), so shan't comment.
Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Suggestion needed from DVD to HD
By onlygk in forum Newbie / General discussionsReplies: 4Last Post: 20th Nov 2010, 05:44 -
Dvd hacks needed
By poisonivy4 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Jun 2010, 10:38 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Authored DVD exceeds DVD spec bitrate - advice needed.
By outerspacerace in forum Authoring (DVD)Replies: 27Last Post: 14th Jun 2008, 22:23 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
