  1. Is there a good simple guide to doing this and what program is best.
    It must have a menu even if its just a simple click for each movie
    please dont post and say you will need to compress as i know all about that.
    they are 2 very small movies (cartoons)
    i also know its not very easy to do but i have to start somewhere
    ps where did the posts of each user go
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    If they are samller than the size of a dvdr (4.37gb) can then just load the files into your dvd authoring program. From there you can make any menus you want.
    If it's larger than a dvdr than author it anyway and shrink the project with dvdshrink or another transcoder.
    Kevin
  3. To answer your latter question, refer to this post:
    https://www.videohelp.com/forum/viewtopic.php?p=1033439#1033439
    The administrator has apparently decided that post counts were more trouble than they were worth, along with "Date joined", because those two items often become status symbols, or "noob alerts", and take away from why we're really here. With a level playing field we can post, and respond, and our posts can be taken at their own value instead of being judged with a pre-conceived "validity".
  4. Originally Posted by yoda313
    Hello,
    Kevin
    so if they are small enough load both movies into say TMPGEnc dvd author
    wont that only create one menu
    what i want is the dvd to start with a menu with the names of the 2 movies so i can select which one to watch..
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Yep.
    Follow these steps:
  6. Great thanks a lot yoda313
