Hi
I am having some problems. I have an mpeg file and an ac3 (which is a 5.1/6channels ac3) file and when I try to create a vob file with dvdauthor it just doesnt want to work. Half way through the muxing a problem occurs, there seems to be a problem with some frames in the ac3 file and dvdauthor stops . There is no sound problem if I listen to the ac3 file, and AC3fix doesnt find any problem with it. I have tried other softwares, but they give me the same problem. So how can I force dvdauthor (or any other software) to mux even if it finds an error (maybe fill the damaged frame with an empty frame?)?
Thanx
Results 1 to 1 of 1
Video Re-Muxing Problem: How to Re-Mux to M2TS?
By WellBeSerious12 in forum Video ConversionReplies: 5Last Post: 15th Sep 2011, 02:31 -
MKVToolnix muxing problem when adding or removing audio and subtitles
By firstliight in forum Video ConversionReplies: 1Last Post: 19th Nov 2010, 08:23 -
FairUse Wizard 2.9 muxing problem
By herbapou in forum DVD RippingReplies: 2Last Post: 17th Mar 2009, 11:21 -
mkv file audio muxing problem
By shun in forum EditingReplies: 2Last Post: 23rd Feb 2008, 08:15 -
Framerate problem when muxing
By baconharvester in forum EditingReplies: 3Last Post: 17th Sep 2007, 18:35
