Hi, I was wondering if there is such a thing as and LCD Adapter for a Mini DV camcorder. My Cam has an LCD attached, but i wanted a sperate screen about the same size...... but attached to a wire 3 or 4 feet long, so its seperated from the camcorder and connects to the S-video connector. And can be used while filming..... is there such a thing and can this be done???
Thanks for your help
Wow, thats alot of money.
Well, I gues that answered my question though. you can use a sperate LCD by using the S-video connector?
I will keep searching and hopefully find something ALOT cheaper.
I was also wondering if there was some way of taking my LCD off my cam and adding a longer cable. I wonder if a repait shop could do that?
Well thanks for the response -
I think if you weren't so much into miniturization, the prices really do drop. I saw some 13" ones for less than $200.00, and a regualr TV with S-video always works. If you can settle for composite video, the options really increase, and you may even find some in your production budget. Remember to keep it out of youor actor's field of view -- who can't resist looking at themselves on TV?
Hello. -
no, I really need something small about 4" or smaller..... the same size as the LCD on the cam (which is only 3.5" in I think). I need it to be portable
Won't accept s-video, but more reasonable price;
http://www.amazon.com/exec/obidos/tg/detail/-/B00005RD8M/qid=1097363092/sr=8-3/ref=sr_...onics&n=172282
or;
http://www.amazon.com/exec/obidos/tg/detail/-/B00005RD8Q/ref=e_de_a_td/102-6419684-745...2&vi=tech-data -
Hi have seen a few of these screens on ebay
Here are some links below,
one thing to look out for is sellers from hong kong etc where you might be liable for import duty.
I have found these from uk
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=32863&item=5524818837&rd=1
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=3204&item=5524174197
Hope this helps
DVi to VGA adapter for acer lcd question
By Denvers Dawgs in forum ComputerReplies: 4Last Post: 2nd Feb 2011, 14:24 -
YPrPb adapter
By BlackBumblebeezzz in forum Newbie / General discussionsReplies: 24Last Post: 19th Sep 2010, 15:11 -
Wireless Adapter
By Sakuya in forum ComputerReplies: 13Last Post: 21st Dec 2009, 23:40 -
LCD TV vs. LCD Monitor for PC gaming
By Xenos80 in forum ComputerReplies: 6Last Post: 13th Feb 2009, 00:01 -
Displaying Photos on an LCD Monitor or LCD TV
By jbsiegel in forum DVB / IPTVReplies: 3Last Post: 25th Sep 2007, 13:29
