HI,
Any one Help me this , I am using NERO6 , And Lite_on Sohw-812s Rom
How Do i chose SP LP EP Modes While i am Burning the DVD movies.
Assuming this isn't a joke post . . . .
What type of DVD movies ? Nero isn't like a standalone DVD Recorder - you don't have nice simple settings. Look in the guides section to the left for guides on copying DVDs, creating your own DVDs etc. You have a lot of reading ahead of you.Read my blog here.
guns1inger
thanks for the responce to my Post, This is not joke, when i am reading the Dvd Recording Instruction it say mode and time, if i go LP or SP i can go up to 180 or 240 min useing this modes, insted of useing standard format like 4.7 GB 120 Min. -
I've never used nero befor to burn a DVD but I know that when burning a DVD on you computer (not a standalone DVD Recorder) those modes (SP LP EP) are completely irrelevent. In order to burn more footage on a DVD simply lower the bitrate of your video file. Or course this will also reduce quality. What you want to do is use a bitrate calculator, imput the legnth of you video, and your audio settings, then calculate the highest bitrate while still allowing your file to fit on the DVD. Thus getting optimal quality. TMPGenc has a built on bitrate calculater that makes a littler easier....How Do i chose SP LP EP Modes While i am Burning the DVD movies.
AS guns1inger mentioner, u have alot of reading to do. There are tons of guides on authoring DVDs
Heres a good place to start:
http://www.doom9.org/index.html?/dv/guide.html
Check out section 3 on encoding....The distance between genius and insanity is measured only by success...
Keepvid - how can you chose where the downloaded file is saved?
By jacknscoob in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2012, 00:09 -
I want to set up a wi-fi but need to choose: ipod or netbook
By vhelp in forum ComputerReplies: 0Last Post: 24th Nov 2010, 20:19 -
Playing MPEG with menu to chose episode
By huborsbeek in forum Software PlayingReplies: 4Last Post: 13th Jul 2010, 05:15 -
CRT TV (SDTV) - when i play 16:9 movies and chose Pan n Scan it doesnt wor
By dzsoul in forum DVB / IPTVReplies: 17Last Post: 14th May 2009, 17:28 -
Archiving DV.avi to DVDROM
By dgpretzel in forum Newbie / General discussionsReplies: 7Last Post: 31st Mar 2008, 14:53
