  1. I have a 5-minute mp3 file that I need to cut the first 30 seconds from. Anybody know a good (free) way to do this?
  2. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    I haven't used it much but I think you can do that in audacity.
    Donadagohvi (Cherokee for "Until we meet again")
  3. Use Audacity as freebird suggests. This should also be located in the Audio forum - I will move this for you.
    Cobra
  4. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    If you want other choices there is a section to the left that says "Tools". There are several audio editors listed...some freeware and some not.
  5. Mega MP3 Splitter
    It's free,fast and doesn't reencode.
  6. MP3DirectCut. Also does not re-encode.
    Happy to be here.
  7. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    I also recommend MP3DirectCut , I've used this several times to cut long beginnings or endings from mp3s and it is a great tool.
    What We Do In Life, Echoes In Eternity....
  8. Thanks to everyone for their replies. Audacity worked fine, and I may try MP3DirectCut later on to hear what it produces. It's 1:30 AM here now and everyone else is asleep so I can't really tell how well it worked, so off to bed it is for me...I'll check in the morning...
