I've got a few xvid's...
The problem is when I play them on my computer...
The sound is VERY low - barely hearable.
On my PC, the sound will be on max!
Every other sound on the PC will be load and clear - but not the xvid.
When played in my divx DVD player... the sound is fine.
How can I fix the problem so that the sound is OK on my PC?
Thanks.
Jam
I used to have an AC-3 audio codec that had it's own volume control and it came configured at -20 dB. So I had the same problem, files with AC-3 audio were barely audible. One day while digging through my audio codecs for something else I noticed the AC-3 volume setting and changed it to 0 dB. It played at normal volume levels after that.
I don't have that AC-3 codec anymore but here's how you can get to the setting:
Go to the Control Panel and select Sounds and Audio Devices. Go to the Hardware tab. Select AUdio Codecs and press Properties. Switch to the Properties tab, select the AC-3 Codec, and press the Properties button. On that dialog there may be a Settings button -- press it and look for a volume control. -
Oh, I have Vigovsky Alexander's AC-3 filter now and it has a configuration option under Start -> All Programs --> AC3filter --> AC3filter Config.
How to increase Video Sound Levels on AVI. Files or Mpeg
By c_a_konopka in forum EditingReplies: 14Last Post: 27th Jun 2012, 21:48 -
Increase sound level of a m4v file
By Neil Crumpen in forum EditingReplies: 1Last Post: 19th Oct 2010, 04:14 -
Can you increase volume of ADPCM sound in movie?
By johnharlin in forum AudioReplies: 3Last Post: 18th Sep 2010, 17:15 -
increase the sound on an iso or dvd
By py52126 in forum AudioReplies: 4Last Post: 15th Aug 2010, 00:37 -
increase the sound of a video?
By sharmine in forum AudioReplies: 3Last Post: 22nd Nov 2007, 12:28
