how do i convert an avi or mpg file to a dat file?
just encode the avi file to mpeg then burn it as a VCD and the software will turn it has a dat file for you ..wasnt that easy
i tried that already.unsuccessful.plus my esy cd creator would only burn as an mpeg and cant play on my player
do you have the VCdmaker option on Easy CD...if you dont download the Deluxe version of your version....did yours came bundled with your burner...that explains it just update to deluxe ..okay
how to seperate audio from DAT file
By pcb in forum AudioReplies: 5Last Post: 4th Jul 2011, 14:51 -
What is the DAT file?
By coody in forum Video ConversionReplies: 3Last Post: 22nd Mar 2010, 20:29 -
.Dat File?
By niteghost in forum Video ConversionReplies: 3Last Post: 24th May 2009, 21:38 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 19:31 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 22:06
