Hi,
I have some vob files (music videos coming from several DVD), I want to make a compilation.
Some files are AC3 (DD 2.0) and other are LPCM.
I author with TMPG DVD Author. For the LPCM tracks, no problem, I put them in the same track.
But for the tracks with AC3 audio some are 192 kbps, other are 256 kbps.
So can I put them on the same track without having compatibility problems ? Or is it better to convert all ac3 to mp2 or lpcm ?
Thx
Hello,
I can't imagine there would be a problem with the different bitrates.
BUT, to be safe why don't you author than like normal and burn to a rewritable disc to be on the safe side. Then you'll know if it doesn't work you won't have wasted a blank.
Kevin
--That's an interesting question. I think I might scrounge up some bonus discs and see if the trailers are at different audio bitrates than the documentaries (it would make sense since it would save them some disc space)--Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Need Help With Deciding on Bitrates
By W1nks in forum Video ConversionReplies: 12Last Post: 6th Dec 2011, 10:17 -
MP4 File Audio Bitrates
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 19th Sep 2010, 10:51 -
WD TV reccomended bitrates
By SCDVD in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2009, 23:20 -
I need some help understanding bitrates...
By pwhyles in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2008, 13:54 -
MP3 Bitrates..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2007, 21:50
