Hi, i'm Currently using Nero vision Express to convert MPG video/audio to DVD. The Transcoding takes about 3-4 hours. Using Ulead DVD movie factory takes twice that!
Is ther a way to transcode faster?
I'm currently merging two MPG's which have video & audio, putting chapters in & then transcoding & burning with Nero. Generally the DVD's are turning out fine but hust wondered if there was a quicker way to do it & how?
Many thanks for any help
Paul
are the mpgs dvd compliant? then author and after dvd shrink it.
I haven't a clue, nero play's them fine & chapters them etc, it just seems to take a long time transcoding them to vob files.
use avicodec to check the video properties and post them here. you can also just try import the mpgs in a good authoring tool like tmpgenc dvd author and it will report it they are dvd compliant.
Transcoding Software
By Prince Valiant in forum Video ConversionReplies: 4Last Post: 11th Sep 2010, 10:26 -
Different Transcoding on Encore
By htalnts in forum Authoring (DVD)Replies: 1Last Post: 14th May 2008, 22:42 -
Nero 8 transcoding question...
By RaGuSNY in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 14:23 -
XP vs Vista (transcoding)
By stiltman in forum ComputerReplies: 17Last Post: 11th Sep 2007, 11:36 -
Batch Transcoding?
By joelore in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jun 2007, 16:42
