I want to copy a Region 0 PAL DVD and am looking for help.
I think the easiest way to do this is to use a multi system DVD player (cyberhome 300) to convert the PAL disk to NTSC out.
I assume the output from the dvd player will be NTSC.
Will I then be able to capture this DVD on my hard drive (using my digital camcorder as a pass thru)as an NTSC video file?
Can I then use that video file in my video editor (Pinnacle Studio 8)
Thanks for any help/suggestions!
you could always rip the film to your pc and properly encode it over to ntsc, but thats VERY timely.
So to answer your question , yes you can. The cyber home will convert the signal over to ntsc and then its just as if you were capturing/recording a regular film.
I do not own pinnacle but their should be no reason why you could not do what you want with it after it is in your pc -
Yes you can.
This is the easist practical way to convert PAL to NTSC. The video gonna be a little bit shaky, especially on left to right / right to left motion scenes, also some flickering may be noticable, but it is not that much terrible.
The other way, to use a PC, needs time and good knowledge of various programs.La Linea by Osvaldo Cavandoli
Multi-System VCRs; PAL N tape, PAL VCR
By darito in forum Capturing and VCRReplies: 14Last Post: 17th Apr 2012, 12:54 -
Best PAL VCR player with 6-heads - multi region/system would be preferred
By jbloggs in forum DVD & Blu-ray RecordersReplies: 7Last Post: 16th Mar 2012, 16:20 -
Any good multi-region DVD player that plays PAL/NTSC and upcoverts?
By jtrinc in forum DVD & Blu-ray PlayersReplies: 9Last Post: 13th Jun 2008, 19:12 -
NTSC/PAL DVD player
By jonas more in forum DVD & Blu-ray PlayersReplies: 24Last Post: 9th Jan 2008, 08:40 -
Multi System VCR to NTSC tv Converter
By Kenneth M in forum Newbie / General discussionsReplies: 10Last Post: 7th Oct 2007, 05:14
