Results 1 to 11 of 11
  1. Tmpengenc can extract the video, but nothing seems to extract the audio properly.
    I've tried virtual bug, avito wav, and tmpengenc as well.
    O followed advise here to convert the metroska file to an avi, and it plays fine, but avitowav did report that it was not a avi file type.
    I opened the metroska converted avi file in graphedit again, and here's what it shows:
    http://webpages.charter.net/gareee/graphedit%20capture.jpg
    How can I set it up to extract the audio, and if it can, the video as well, so dvd author can author a dvd properly?
    Gary Tabar Jr.
  2. Anyone?
    Gary Tabar Jr.
  3. Demux the audio with virtualdub....
    The distance between genius and insanity is measured only by success...
  4. Virtualdub errors on opening reporting: "can't detect filetype for POTV.avi
    The avi was created with graphedit, from an original matroska file
    Gary Tabar Jr.
  5. I finally gave up.. I just watched the avi off the system, and I'll archive it on a disc.
    Gary Tabar Jr.
  6. The problem is I have an avi, and want to make a dvd, not a svcd...
    Gary Tabar Jr.
    Apr 2004
    Miskatonic U
    Garee - did you even look at DVD2SVCD - it will produce a DVD as output as well. One click would have told you this.
    Read my blog here.
  8. Use Goldwave to extract the audio into wave file.
  9. Ok, I'll try one more time.. I'll grab goldwave, and report the results...
    Gary Tabar Jr.
  10. Goldwave actually worked flawlessly! No messy settings, or tinkering either.
    I'll need to re-rip the video again, and then make a dvd image from that. I'll try it tomorrow...
    Gary Tabar Jr.
