  1. I have a video_TS folder that i need to shrink down. When I go to use dvd21, it won't let me do a disk copy as the video_ts apparently is missing one of the files. But I don't want to do the movie only, as it will leave out alot of the information I want to transfer. Is there a way I can tell dvd21 to include various files?
    Or to burn, waht will happen if i leave out some of the vob's, will the disk burn incorrectly?
    thanks
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    not really, dvd2one will only work if the video_ts folder is intact. Just re-rip it and you will have an intact folder, then you can process it normally
    most likely you cant just burn it now because its too big.
