I want to DVD author some DVD-AVI files that I captured from an analog tape that I recorded with a Hi8 NTSC Analog Sony Camcorder. I want to burn the DVD at the maximum quality possible. I plan to use one DVDR5 for one hour of video and set the bitrate to 9000kbps. Is this bitrate excessive? Can I use less bitrate and fit more than one hour and still not sacrifice on video quality? (given the fact the original video is a Hi8 footage)
Also, regarding audio settings, I plan to use either 320kbps MP3 or PCM. I assume PCM is better quality, is it worth it? (the original Hi8 video is Stereo, 16bits, 48khz).
Thanks.
calculate how much you can fit on a dvd-5, www.videohelp.com/calc
you cannot use mp3, only mp2/mpa, ac3 and pcm. read lordsmurfs audio guide for some info about quality, https://www.videohelp.com/guides.php?guideid=445&howtoselect=3;56#445
and this is not dvd authoring. it is more conversion related. moving you.
Authoring high quality audio DVD
By carlmart in forum AudioReplies: 14Last Post: 17th May 2010, 08:40 -
LINUX: AVI to DVD Encoding and Authoring : BASIC
By disturbed1 in forum User guidesReplies: 13Last Post: 5th Feb 2010, 21:43 -
Authoring DVD frm AVi files using DVDAuthor
By sumit_pankaj in forum Authoring (DVD)Replies: 5Last Post: 19th Jun 2009, 14:01 -
preserving quality in DVD (HD) authoring (matroska)
By pay1000 in forum Authoring (DVD)Replies: 11Last Post: 22nd Jul 2008, 09:20 -
Any DVD authoring tools that are geared for quality + size?
By timmus in forum Video ConversionReplies: 4Last Post: 25th Oct 2007, 00:38
