ok i have this mpeg file that is 4:3 and on my 16:9 tv it looks awfull because de image is streched, so i would like to know if theres a better way to encode it in Tmpgenc so that it will look better in my 16:9 tv
thanks in advance
dont you say
yeah i know about that its just that i dont like to use the 4:3 mode because of the black bars it creates -
On my WS TV, my 4:3 mpegs have vertical black bars. You are saying you don't like these?
Open TMPGEnc and open your source file, and unlock the "Settings"
First use Settings->Advanced->Clip Frame(checked)
Then double click Clip Frame and change top and bottom values to crop to 16:9
Then set "source video" to 4:3 (PAL/NTSC ?)and "video arrange" full screen keep aspect ratio
Then go to Video Tab and set "aspect ratio" to 16:9 (PAL/NTSC ?)
This makes an anamorphic mpeg that will (when your TV is on 16:9 mode) fill the whole screen - although, of course, you lose the top/bottom of your original movie.
<font size=-1>[ This Message was edited by: ember on 2001-11-25 19:50:55 ]</font> -
On 2001-11-25 18:18:58, GajoTNT wrote:
dont you say
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
The black bars are as good as its going to get. Unless you stretch the 4:3 to fit the full width of the 16:9 and cut off the top and bottom, which would look terrible. -
If you really hate those vertical black bars, add some silver drapes at the side to simulate the silver panels of a standard 4:3 TV.
<font size=-1>[ This Message was edited by: ember on 2001-11-25 19:57:39 ]</font>
converting MPEG-TS to MPEG-PS (from a Noontec V9)
By ninereeds in forum Video ConversionReplies: 2Last Post: 28th Jul 2010, 10:17 -
What software is good for converting to DivX..?
By Karel Bata in forum Video ConversionReplies: 6Last Post: 8th Dec 2009, 12:36 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51 -
Mpeg-2 is not good for editing
By totalfreedom in forum EditingReplies: 13Last Post: 8th Mar 2008, 16:01 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 15:04
