i have just learned how to make a dvd movie and burn it to a dvd disc.
i have LG medias and LG dvd player and it plays the medias perfectly, but i have also Hyunday dvd player that has a problem playing the same disc-it reads the disc ok but the picture is distorted.
what makes the problem-the disc or the dvd?
It could be either. I have made dvd's with a settop recorder and with my pc. We have a few different players plus the drive in the pc. There have been times in my case where, right from the start a dvd plays fine in the pc & the panasonic settop recorder, but has problems on the apex in my daughters room. this would seem to be a problem with the apex, being an older unit. Other times I have had discs that worked on the apex for awhile start to play funny, stop, stutter, etc. I'd check them on the panasonic and it was funny there too. It was on some of the "bargain" media I purchased. Your best bet is too have as new of a dvd player as possible, check for updates for the firmware for your pc dvd drive, and use quality media.
10x for the reply, i will try to buy other medias and if it still doesn't work i guess i will have 2 buy a new dvd...
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
Complex problem, extra some chpts from 2 dvd and combine into 1 dvd + menu
By Shihtzu88 in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2009, 08:09 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 03:26 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 21:37
