Can someone explain clearly what the difference is between progressive scan and field order? Does this feature make a video better? And when it comes to purchasing a camcorder, is progressive scan support a plus? Why??
Thanks.
You have your terms a little confused. Rather than try to explain here, have a look at this site, created by one of the members here. It should help you understand it all.
http://digitalfaq.com/capture/interlace.htmRead my blog here.
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 04:12 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
Swapping field order in progressive video.
By jmail524 in forum Video ConversionReplies: 1Last Post: 3rd Aug 2008, 13:53 -
DV Lower Field First - can be rendered as progressive scan ?
By tarrickb in forum Video ConversionReplies: 2Last Post: 30th Jul 2008, 08:19 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14
