  1. Member chicola's Avatar
    Nov 2003
    Outside the Matrix
    Could you give me your advice on a good DV video camera that could do analog-digital passthrough conversion on-the-fly. Preferably with a horiz. resolution of 720.
    Any personal experiences?
    Is there any place in this site where I could find this info?
    TIA
    "Adopt, adapt and improve!"
  2. Member vhelp's Avatar
    Mar 2001
    New York
    From experience, the Sony TRV22 dv cam is an excellent contender.
    It provider very good quality DV - to - AVI passthrough quality.
    In fact, I'm amazed, between the comparisons w/ my ADVC-100 and the TRV22
    cam.
    I have not done any actual test comparisons of the two above, but FWIW, if
    you are serious enough, and have other needs thant what the ADVC-100 can
    do for you, then the TRV22 is probably your best solution (based on experience)
    Good luck,
    -vhelp
  3. I have a Canon Optura 10(miniDV) and it produces great video,it's an older model but you can still buy it for around $400USD.
    You can find other analog passthrough camcorders HERE.
  4. I have a Sony DCR-PC101. It works great and I love the passthrough.
    If I was to get another camera, I would probably be looking at 3CCD cameras for better low light performance. DV cameras fall behind the old VHS in this due to the smaller optics.
    One thing I love about some of the Sony's is the touchscreen display. Makes it so much easier and faster to change settings while your still filming.
    Thought they all do 720?
    Dec 2002
    Costa Rica
    I decided to buy a new Digital8 camera to convert old Video 8 and Hi8 stuff to DVD. I recently got a DCR-TVR361. It has analog-digital pass through, night shoot and a memory stick slot.
    I’m disappointed with its low light performance because my older CCD-TVR608 Hi8 was better. Finally I’m not trilled with the touch screen display, but you know what they say about opinions.
  6. Member vhelp's Avatar
    Mar 2001
    New York
    Hi guys.
    yeah, I also like the touch-screen feature of my TRV22 cam. At first, you
    hate it, then, once you figure out its hidden techniques, you almost don't
    want to go back to the manu hard pressing button, which are usually in the
    wrong places anyways.
    And now, for a little OT here ...
    I'm also thinking about getting me a Dig8 or High8 cam. But just for my
    8mm tapes. I have a box or too full of them, and I don't want to run them
    through my old 8mm cam because the heads are bad (dirty among other
    things) and it only has Composite connection. Also, because of the line noise
    in my captures, (they too, are pretty dirty) I want nothing but the best in my
    transfers ( 8mm home footage - to - DVD ) and only DV can provide this
    FWIW.., I finally got my pc to recignize my DV cam, but only RsDvCap.exe can
    reciginize and produce a video in a window for me. Even in low-light conditions,
    the source (to my amazement) was superb. It works, but only in Type 1 AVI files.
    For now though, it works.
    But, I was so amazed ( its ben a while since I last saw any home-footage through
    my DV cam and onto my PC in DV .AVI format ) at how crystal clean the video
    was on my pc (inside virtualdub) No noise and No discoloration. This is
    something that an Analog Capture card can *not* produce if I capture it from my
    OLD 8mm cam through Composite connections.
    FWIW to note here..
    However, in the short tests I ran last night, I found that going from an
    Analog source to DV (via passthrough) was very good, but ONLY if there
    are NO NOISE in your source. Some examples of Noise are VHS (even
    commercial tapes) and noisey Antenna signal ( which mine has ) results in
    a slightly lesser quality once through a DV passthrough conversion.
    So, my hunch is like this. If you have 8mm tapes and a High 8 (DV) that can
    read these 8mm tapes, and because you are not going through any other type of
    connectors (Composite) and Wires, you will (or should) get optimum quality
    conversion from those 8mm tapes.
    I really need to try this out.
    But, to be sure, my question is this..
    * What type of dig8 / high 8 cam do I need to get ??
    Thanks guys,
    -vhelp
