Hi.
I have DV footage with 48 KHz 16 bit stereo audio. I would like to encode it to DVD.
Which format shall I give preference (space is not an issue since the DVD will only be half full)?
1. PCM
2. AC3
3. MP2
Is this the right order, quality wise speaking?
If I would encode the audio above with AC3, would 5.1 be the best option? I wonder if 5.1 would be usefull, since the source material in only stereo.
TIA
I'd say that PCM would be first(because it is uncompressed), then AC3 and MP2 are about even on quality, however I would give a slight edge to AC3 if you are using NTSC.
As far as I know, there are no non-commercial AC3 encoders for 5.1. The best you could get would be 2 channel(stereo).
Also, depending on the audio system you will be using for playback(receiver), some have issues with MP2. They will most likely play(I have not found one yet that has an issue playing), but the audio might be "tinny" or "staticy". I have a buddy who has a receiver that shows the "staticy" stmptom if the ausio is played too loud. On the 5 other systems I've tried, the audio was fine. -
If space is not an issue, then go with PCM, as quality wise its better than the other two and 5.1 is pointless if your source is stereo.
Thanks for the replies.
What if I put (theoretically speaking) all 3 audio streams on the DVD, which does the player use as default?
Is this default audio stream defined inside the player or while authoring the DVD?
TIA -
It will use whatever you assign as the default audio track (the first track) when you author it.
So yes its when you author it and not the player. -
NTSC DVD discs can only contain either AC3 or PCM audio.....it cant contain MP2 audio. PAL discs are the exception.Originally Posted by geohei
VTMI have the staff of power, now it's up to me to use it to its full potential to command my life and be successful. -
You should preceed that with "According to the NTSC DVD specs..." and then finish it with "...But, there seem to be more and more NTSC DVD players that will play MP2, though it's not guaranteed."Originally Posted by VideoTechManThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
