  1. I am using TMPGEnc to convert .avi to mpg
    i werks for a bit then my comp freezes
    i used virtual dub but i still get the same prob.
    any ideas???
    thanks
  2. did you download your movies? If so, you have bad frames which you have to delete. Get Vdubmp3.exe to check for bad frames(freezing frames) Get it at http://www.iampornostar.com. Once there, click on divxtools on your left screen.
    <font size=-1>[ This Message was edited by: gadget on 2001-11-25 16:59:54 ]</font>
