My IEEE 1394 firewire happily recognises my removable hard drives every time. But when I plug in a Sony SDR-15 DVCAM, or Canon MV530i camcorder, I do not get "New hardware Detected", and forcing a scan for new hardware does not recognise the DV devices either.
I've tried re-installing the VIA Technologies SBP2 IEEE 1394 drivers... and only my removable drive was re-recognised.
Some web sites suggested I remove the DVCAM.INF and DVCAM.SYS files from my Windows drivers, but they do not exist.
I have installed no software or drivers for the DV devices, as I believe non are required.
I'm running MS Windows XP with SP2 installed.
Suggestions appreciated.
Regards,
Ian Tresman
Derby, UK
Problem solved. It was a faulty cable, dammit.
Now when I plug into the PC, I get New Hardware Detected on the task bar, followed by some more information about the type of device, followed by the name of the device.
After which, a pop-up menu appears asking if I want to Capture video. Alternatively, I can choose to capture video with MS Movie Maker, or WinDV, without any problem.
Regards,
Ian Tresman -
Man, I´m facing the same problem...windows XP doesn´t recognize my DV Camcorder. I´ll test the cable tomorrow and then I send you a message, ok ?
Bye...
Canon HV40 not recognized via firewire
By ThanosK in forum Capturing and VCRReplies: 16Last Post: 30th Dec 2012, 10:54 -
Sony DVCAM
By gash69 in forum Newbie / General discussionsReplies: 0Last Post: 15th Jan 2011, 10:36 -
Sony DVCAM and AV/C tuner driver problem
By Sean_ve99 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 2nd Nov 2009, 19:34 -
Sony DSR 200 rewind problems
By ssadams in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 29th Feb 2008, 08:37 -
Womble doesn't recognise avi audio from my Samsung Digimax
By keveen in forum AudioReplies: 2Last Post: 26th Jul 2007, 17:24
