I converted an XVID avi (688x384) to a standard VCD file using mpeg2enc. The resulting VCD is much darker than the XVID. Although, the XVID file (captured from HDTV) was dark to begin with given that most of the show takes place at night.
I'm pretty cluelss about video conversion. I just let ffmpegX do it's thing. So, how can I get ffmpegX to increase the brightness of the output VCD?
Okay, I'll give that a try. Will disabling "Decode with Quicktime" affect the output VCD in any other way? For instance, will it still have the widescreen black bars?Originally Posted by major
Also, if I disable "Decode with Quicktime," what will ffmpegX use to decode the XVID file? I hope it doesn't use whatever the fast VCD (VCD ffmpeg) setting uses because the resultings files always have out-of-sync audio for me.
1/ Letterboxing will be available but only for 16:9, not 2.35:1
2/ It will use ffmpeg
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 16:00 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 17:03 -
best avi (divx/xvid) to cd-r (vcd) converter
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2008, 13:36 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 17:51 -
Vista beginner needs help with video conversion! Xvid to VCD with subs
By Joakim_A in forum Video ConversionReplies: 2Last Post: 23rd Sep 2007, 03:59
