I am a rank newby, my other computer is chugging on my first DVD to SVCD conversion (using Sefy's excellent guide). In SmartRipper what are some guidelines for the Stream Processing options, particularly with multi-language, subtitles movies. If I want English language, should I click on 'process streams' and then the English stream and leave other languages off? What about subtitles?
Select what you want to copy to HD, uncheck the rest.
If you want to end with a .vob file, that contain video, audio and sub files, select direct stream copy. If you want to save each track as a seperate file, select demux to extra file.
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 22:42 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 04:40 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
FFMPEG Stream mapping options result in conversion failure
By JackJack in forum Video ConversionReplies: 6Last Post: 27th Jun 2008, 23:19 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27
