  1. im trying to fit and 705mb file onto a data cd-r which is 80min/700mb...is there anyway to make it fit? ive tried turning on the overburning option,but still no luck
  2. Originally Posted by ginneypig
    Are you trying to say that the overburning feature can't be turned on or that you can't overburn a CD even after turning the feature on?
    If the first is true, then your CD burner doesn't support that feature.
    If the second is true, then try to ZIP the file and burn the zipped file.
  3. when i turn on the over burning feature, it still says not enuff room on disk bla bla...but ill try the zipping it 1st.
