does any one know of a simple way to convert my 2 disc vcd to 1 dvd disc???
Hello,
Use isobuster to convert dat to mpg if its in that format. Then use tmpgenc dvd author to make the dvd.
Try Just AQdding the *.dat files that are the movie into tmpgenc DVD Author, it will convert the Audio and author the DVD. That is what I've been doing and it seems that it'll let you add the files straight off of the VCD.
However of course YMMV
Roger
Quick easy way to convert DVD subs from 25fps to 23.976fps?
By nick1977 in forum SubtitleReplies: 19Last Post: 22nd Feb 2015, 18:36 -
How Can I Convert DVD to HD 1080p resolution as easy as HD 720p
By hd hackerz in forum DVD RippingReplies: 5Last Post: 11th Jan 2011, 04:54 -
Easy way to convert MiniDV to DVD?
By darkcyber in forum Capturing and VCRReplies: 5Last Post: 10th Mar 2010, 15:46 -
PAL to NTSC DVD [Full Disc] Conversion (hybrid method, very easy)
By LadyLiete in forum User guidesReplies: 28Last Post: 5th Nov 2007, 21:35 -
Easy way to convert DVD to mp4 files on a PC?
By gwoiler in forum DVD RippingReplies: 4Last Post: 31st May 2007, 15:53
