I have a surveillance camera that I wish to connect to my PC to capture video with.
I want to be able to specify a time for the capture to start and end.
Is there a program that will do this on a windows 98 system?
Also I don't know which capture card I'll be using yet, but as long as it had s-video/composite inputs will any work?
Thanks in advance for your help!
You won't be able to capture more than 4 gigs on that system. That limits your recording time.
You could get an ATI All in Wonder from ebay.com those should if you can get their recording software. -
Ah yes the 4GB limit. I shall put my copy of windows 2000 on in that case.
The only problem is the pc I'm using has no PIC slots at all, it's a micro ATX thing. is there an extrenal solution I could go for? -
Go to www.gotchanow.com. It will do motion sensing, break the files up in to any size you want. It will recycle files and also take clips. I use it at quite a few different sites. It runs unmanned.
I am using some old ATI Rage Pro's with VIVO...
Help all codec packs don't work with my surveillance cam
By uc1 in forum Newbie / General discussionsReplies: 4Last Post: 13th Sep 2011, 14:07 -
Good basic vid editor that can handle .mp4 movies from FujiFilm S2000HD cam
By coffeecup-sf in forum EditingReplies: 3Last Post: 21st Jun 2010, 23:24 -
What are Good software i can use to record videos with my web cam or camera
By jace89 in forum Capturing and VCRReplies: 0Last Post: 21st Dec 2008, 16:08 -
Good Starter Cam in a tight budget?
By acid_burn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 4th Aug 2007, 00:48 -
minidv for surveillance
By bobbykey in forum Newbie / General discussionsReplies: 6Last Post: 6th Jun 2007, 17:07
