I want a DVD Recorder with component inputs and outputs, do they make them? Does anyone know of any?
How does recording work on a write once disc? Can I stop recording, then continue recording later where I left off on the same disc? Or does it finalize the disc once you stop recording? Is it the same on all models or does this vary from model to model?
Results 1 to 17 of 17
Whose dick do I have to suck to get an answer around here?
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Capmaster
Let's see. It took just 1 hour and 42 minutes waiting for a reply before you offer oral sex. If we wait longer what will you offer next?
Ouch!
Yes, until the disc is full.Originally Posted by FJACKIE -
Wouldn't that be a little difficult while you are servicing him orally?Originally Posted by FJACKIE
I don't know all dvd recorders which is why I can't answer your first question about the availability of any that have component inputs as well as outputs. I think it would be silly for any DVR manufacturer to try to compete in the market with a recorder that only allows one burning session per DVD. Naturally, if you are using write-once media such as DVD-R you don't want to finalize the disc (you have to choose this; it doesn't happen automatically) if you plan to add more to it later. Re-writable discs can be erased and re-used even after they have been finalized. If you burn to rewritable media in VR mode you can actually erase titles and re-use that space without having to re-initialize the disc.
Try Philips/Magnavox, specifically the Philips DVDR-615 and the Magnavox MRV-64017.Originally Posted by FJACKIE
Kind of an "old" model to be buying now, isn't it? Also, aren't the DVDR75 and DVDR72 virtually identical? I know WalMart is selling the 72 for around $229.Originally Posted by zorankarapancev
Personally, I'd go with the 615 since it's a newer model. Further, I'd get the extended warranty, protection plan, or whatever; after all, it is a Philips. -
So is Philips the only brand that makes dvd recorders with component inputs? Why is that? I have had a bad history with Philips brand electronics.
Philips/Magnavox models are the only recorders I've seen that have component inputs. No idea why that is the case.Originally Posted by FJACKIE
Ditto. Hence the suggestion to get some sort of replacement plan if you decide to buy one of their products, regardless.Originally Posted by FJACKIE -
Other than Philips, there is Yamaha with Component input.
http://www.yamaha.ca/av/DVD_PLayers/DRX2.jsp
http://www.yamaha.ca/av/DVD_PLayers/DRX2/Brochure.asp
http://www.yamaha.ca/av/DVD_PLayers/DRX2/Back_Panel.asp -
That DRX2 looks interesting but what's with the pricing and availability?
I mean, I did a Yahoo! shopping-type search for it and only came up with a few vendors. Further, the prices were in the $600 range.
Yamaha DRX-2 i supposed to be a Philips DVDR77... With some slight modifications. But its still a Philips.
couple newbie questions - DVD to MKV and watch on WDTV
By timmyinnis in forum Newbie / General discussionsReplies: 7Last Post: 26th Apr 2010, 03:14 -
a couple of sub questions
By Kanyeeeze in forum SubtitleReplies: 1Last Post: 1st May 2008, 17:03 -
A couple of general newbie questions
By serpetary in forum SubtitleReplies: 5Last Post: 21st Mar 2008, 11:01 -
a couple of questions ..
By ZaYoOoD in forum AudioReplies: 6Last Post: 7th Mar 2008, 14:21 -
couple questions
By mainegate in forum ffmpegX general discussionReplies: 2Last Post: 31st Aug 2007, 11:22
