Hi all i have a little problem.
I have a Terratec cinergy 400 and wanna capture my satellite signal to mpeg2 dvd pal format (720x576) with windvr 3.There are black borders on top and bottom of the signal (cause i acquire 16/9 movies) with the sky logo on the upper right.
Can i crop the two border (like what i would do if acquiring in divx) and then author directly the mpeg ? The crop will change the resolution...is this a problem for dvd format ?
Any help ?
Ashram
Results 1 to 1 of 1
Capture from DVI or Composite
By bb69 in forum Capturing and VCRReplies: 3Last Post: 21st Aug 2009, 10:37 -
VHS Capture - S-Video or Composite?
By Killer3737 in forum Capturing and VCRReplies: 21Last Post: 19th Apr 2009, 06:29 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 10:55 -
compressed capture with composite
By benaw in forum Capturing and VCRReplies: 2Last Post: 20th Nov 2007, 08:09 -
Intensity Pro Composite capture.
By trydowave in forum Capturing and VCRReplies: 0Last Post: 22nd Oct 2007, 18:37
