i'am sure this is possible to do and i'am searching in all forums without finding it.
I want to write a folder video_ts containing normal dvd files (100 mega) on a normal cd-r .
Nero express 6 refuse saying i have to put a dvd on writer.
it is possible ti write a DVD structure on a normal cd-r / rw and this play fine on cd and standalone player?
tks in advance - Marco
Results 1 to 10 of 10
tks in advance,
Marco
Italy
"... the more I know, the less I understand " Don Henley - EAGLES -
Hello,
Search the guides (on the left tab) for "CVD". It's a dvd structure on a cdr. Very few dvd players will play it normally. Of course, a pc should do it just fine. And you won't be able to get very much video on it due to size restrictions of cdrs.
Sorry to contradict, but CVD is roughly speaking SVCD @ 1/2 D1 resolution. DVD structure on CD is usually called miniDVD, and is handled by some players. Even for those, you get into trouble when the bit rate of the video exceeds the data rate possible for the DVD reader to read from a CD (they are usually 2x readers). But if you keep the bit rate low (not above SVCD bit rate) it may work.Originally Posted by yoda313
/Mats -
YES Baldrick, i remember this format was mini-dvd it was the first words i try with search but comes out mini-dvd for camcorder.
The problem is "how can i write" : nero express refuse to write a VIDEO_TS folder on a cd-r . anyone knows what burning soft accept this ?tks in advance,
Marco
Italy
MINI-DVD feature not present in mine nero 5.5.10.15
since when it is?[/quote]tks in advance,
Marco
Italy
Yes miniDVD is what you need, upgrade your version to Nero Ultra 6.
Author with something that doesn't insist on burning - just create ISO image. Then burn the image (using "anything", including Nero)
/Mats -
WORKS MAT ! So logical in fact - unfortunately only in pc and in only one of my standalone player - thanks a lot anyway.
tks in advance,
Marco
Italy
just wondering - can normal dvd player hack to play hd-dvd
By chanra in forum Newbie / General discussionsReplies: 16Last Post: 12th May 2009, 22:00 -
Is it normal? My DVD recorder records dvd with bit rate 4505.6?
By szalaikornel in forum Video ConversionReplies: 11Last Post: 14th Jan 2009, 11:52 -
normal audio cd from a dvd movie soundtrack
By hilario in forum AudioReplies: 19Last Post: 19th Nov 2008, 16:50 -
Burning HD to normal DVD + other questions
By Gaelstrom in forum Authoring (DVD)Replies: 4Last Post: 30th Oct 2007, 17:02 -
is possible to burn HD video to a DVD and play it on a normal DVD player?
By kozmo62 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 16th Jul 2007, 12:54
