I dont understand this in this guide on doom9 http://www.doom9.org/index.html?/mpg/vcd2divx.htm
asks u to convert DAT to MPG. Doesnt VirtualDub already accept DAT files then whats the sense behind conversion. Moreover when I converted a few clips from DAT-->MPG one of the MPG files had some error in audio stream and thus the file couldnt be reencoded I just used the original DAT file in VirtualDub to reencode and it worked just fine.
A DAT is not an MPEG.
A DAT is an MPEG with other data attached.
This other data can cause problems.Want my help? Ask here! (not via PM!)
Hello,
Lordsmurfs right. Dat is a container for the vcd spec. The authoring program makes the videocd (or svcd) structure so that the player can read it as a vcd. It's the same way when a dvd authoring program makes a dvd structure from an mpg. It creates the video_ts folder with the vobs/ifos/bups that the dvd player needs to know that it IS a dvd.
But then when VirtualDub loads the dat file and converts to AVI directly then why do we need to convert it using VCD Gear at all. Is there a change in quality or something if u use a DAT file as source directly?
You are MUCH less likely to get pic decoding or audio sync errors on your output file from VDub if you extract the *.MPG from the *.DAT 1st. The extra RIFF headers just confuse the (many) programs.
Use VCDGear, VCDEasy etc.
Sometimes you'll find using a *.DAT may work, but I wouldn't count on it.
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 10:25 -
DAT/MPG to VOB/MKV?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 30th Jan 2011, 05:21 -
convert DAT TO avi
By skorpinok in forum Video ConversionReplies: 1Last Post: 27th Nov 2010, 03:53 -
Algorithm convert DAT to AVI
By Nemo_wf in forum Video ConversionReplies: 5Last Post: 5th May 2010, 03:18 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51
