Hello![]()
Im making a backup of a PAL DVD (R2) movie to Xvid and I need help
from a proffesional with cropping and resizing settings.
The original video resolution is 720x576 but I have analyzed a
screencapture made (at 100% vieweing size) in my DVD software.
The screencap has a:
DAR (Display Aspect Ratio) of 960x540 pixels [1.77:1] and the true
VAR (Video Aspect Ratio) is 960x518 pixels [1.85:1]
According to my calculations and some test rips I have found 2
options where the AR looks good and the full true video area will be
included (in other words two options I will be satisfied with):
Option 1:
Cropping 640x344 [1.85:1] (not exactly but often used as Avi 1.85:1)
Resizing 640x360 [1.77:1]
Option 2:
Cropping 624x336 [1.85:1]
Resizing 624x352 [1.77:1]
Which option should I choose to get the best quality and why???![]()
I dont choose 640x352 cause then I have to cut out parts on the right/left.
(please dont give me a third option since Im already satisfied with theese two options)
Note: In option 1 the height is not dividable by 16, is this gonna cause any trouble or will it work anyway? (In option 2 both width and height is dividable by 16)
Thx/ AquaStealth![]()
Results 1 to 1 of 1
Good Long Range Wireless Keyboard/Mouse Solution
By greymalkin in forum ComputerReplies: 3Last Post: 1st Apr 2012, 18:49 -
Help me find the right solution please.
By abeaty in forum Video ConversionReplies: 8Last Post: 7th May 2010, 22:12 -
Where can i find a good HDD Recorder?
By DroWni in forum DVD & Blu-ray RecordersReplies: 20Last Post: 2nd Oct 2008, 13:14 -
Trying to find GOOD programs
By gbabione in forum Authoring (DVD)Replies: 6Last Post: 23rd Dec 2007, 17:39 -
Need new (cheap) capture solution-what to get? Are TV tuner cards any good?
By wickeddvine in forum Capturing and VCRReplies: 1Last Post: 16th Jun 2007, 09:50
