Dear all,
I recently installed the Videostudio mpeg4 plug-in and DivX from www.divx.com, however, when I try to save my Videostudio project off to DivX format there is no option for DivX!?
The mpeg4 option is there, I had hoped I could switch codec to DivX but only the ulead mpeg4 one shows up. I didn't realise until afterwards that this mpeg4 format is not playable with Windows Media player.
Can anybody help?? Basically I wanted to create my movie in Videostudio and then convert to mpeg2 and DVD, then to mpeg4 for archiving, all from Videostudio.
Thanks in advance for help.
Results 1 to 1 of 1
How to Create FLV files from AVI material ( Xvid / Divx )?
By devilcoelhodog in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2010, 09:31 -
How to create a DVD using multiple DIVX/XVID files with Menu
By Amourek in forum User guidesReplies: 2Last Post: 2nd Mar 2009, 08:57 -
How do I create a DIVX w/correct aspect ratio
By peggypwr1 in forum Newbie / General discussionsReplies: 5Last Post: 3rd Oct 2008, 09:16 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36 -
How to use Sub2Divx to create DIVX file with switchable sub
By hmanhha in forum SubtitleReplies: 2Last Post: 18th Mar 2008, 08:55
