Hi.
A newbie question.
Search functions used but no clear answer was found.
I have PCM 48000 Hz 16 Bit and would like to make an AC3 stream (for DVD authoring) out of it.
Which tool works best and offers most AC3 encoding options?
TIA
Personally, I use the encoder that comes with TMPGENC DVD Author. There are some free ones, like BeSweet and HeadAc3e, which are trickier to use, and have some compatibility issues, it just depends on how much you want to spend and how much time you want to put into it.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
(edit) Oh, never mind...I'm not sure why this one is in breach of rules, so I won't touch it.
"What? Huh?!? WHAT will come out no more?!?" Jack Burton -- BIG TROUBLE IN LITTLE CHINA -
Hi geohei,
I second maek - ffmpeggui and an authoring app that support elementary streams. It's quick and simple.
I know for ffmpeggui (and probably the others mentioned) that the output is only 2 channel AC3 - not full 5.1 (6 channel). To do this is a lot more involved, requiring a 6 channel source (usually) and costly.
But, if you just want to save space then AC3 from ffmpeggui is good.
As for authoring, the TMPGEnc DVD Author that Forum Troll refers to is the latest version that comes with the AC3 encoder. There are earlier versions that don't have this.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I second ffmpeggui - never had a problem with this, even if there are claims that the AC3 produced is slightly off standard, making a few Panasonic players fall over...
/Mats -
That is just his signature...it isn't realy in breach of the APUOriginally Posted by maekNo, I'm from Iowa. I only work in outer space.
Oh, in that case, I retract my edit. Yes, you won't find many arguments against ffmpeggui. And it's free free free. My Sony player has no problem with it whatsoever and the PowerDVD platform on my computer doesn't find issue with the file either. You just need to make sure that you have someway of incorporating the elementary audio stream with an elementary video stream through the use of a DVD Authoring program like dvdauthorgui (my current favorite) or other software that can multiplex (join) the streams.
I can't speak for Panasonic players though...has anyone else heard of AC3 compatibility issues (using ffmpeggui) with players? It may effect his "encoder of choice.""What? Huh?!? WHAT will come out no more?!?" Jack Burton -- BIG TROUBLE IN LITTLE CHINA
ffmpeg encoding to xvid + ac3 5.1 -- can't make it work!
By suroit in forum Video ConversionReplies: 2Last Post: 4th Jan 2012, 17:13 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
Make an xvid/avi from DVD but keep original ac3 surround sound?
By coolchris in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 08:35 -
Trying to get Yamb to work with a AC3 file to make a mp4...
By AndyD in forum AudioReplies: 2Last Post: 13th Jan 2008, 00:07 -
need program where i can take aac in apple movie trailer and make it ac3
By marinerules in forum AudioReplies: 1Last Post: 19th May 2007, 03:17
