Results 1 to 9 of 9
    Apr 2001
    Nevada
    Hopefully someone can shed some light on a problem i've recently
    noticed.
    I'm trying to convert a few Xvid encoded file to dvd standard mpeg.
    Whats happeneding is that the converted files play fine, but about
    5 or 10 minutes into the file, the audio dropsout for the duration
    of the file.
    I'm using Canopus Procoder V1.01.35,
    as well as Tmpgenc V2.58
    The avi files, after i ran them thru avicodec, show the following specs:
    Video: Xvid mpeg4 (1087 kps, 25.0fps
    Audio: AC3 DVM (384 kps, 4800Khz, 5channels
    Anyone with some help?,
    thanks,
    Win
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi winman42,
    I've never used Canopus, so I can't comment on that.
    As for TMPGEnc, I don't believe that it can handle AC3 as an audio input format.
    Extract the AC3 from your Xvid and encode the video only. You can then add in the AC3 audio in during authoring to DVD (assuming you're going that far).
    Hope that helps. Good luck...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    Apr 2001
    Nevada
    thanks for the reply...well, Tmpgenc is accepting the file, and as i said,
    its playing fine for 10 mins or so, then the audio stops.
    What would you recommend to separate the ac3 audio from the video?
    I'm assuming i'll do that, then use the separate ac3 audio, when I
    import the encoded video file into Ulead dvd workshop, or something
    similar.
    Win
  4. Member daamon's Avatar
    Melbourne, Oz
    Hi winman42,
    When you're encoding the file in TMPGEnc, set it to do "ES (Video only)".
    As for extracting the audio, I believe that VirtualDub will do this for you - set it to "Direct Stream Copy" in the "Audio" settings and save to filename.ac3. If I'm wrong, then there's guides covering Xvid / Divx -> MPEG conversion with AC3 audio - that'll be something to read up on.
    Originally Posted by winman42
    ...then use the separate ac3 audio, when I
    import the encoded video file into Ulead dvd workshop...
    Exactly.
    Carpe diem.
    Apr 2001
    Nevada
    Well, i took the advice given, used Virtual dub and stripped out
    the ac3 track, then i used tmpgenc to convert ONLY the video
    track.
    I imported both into Ulead dvd workshop, and it worked fine.
    When playing the files in Workshop, it was horribly out of sync,
    but i burned the disc to dvd-rw anyway, because i was curious
    to see if the ac3 tracks worked.
    When i played them back, they were insync!! and the 5.1 tracks
    were retained.
    The only problem now is that i have 2 video files. The 1st worked
    fine, but when trying to import the 2nd ac3 track, ULEAD gives
    an error telling me i have a file format mismatch. Not sure why
    the first file worked, but NOT the 2nd. I've tried restripping the ac3
    track again, but it still fails. COuld it be that the AVI file is corrupt?
    and if so, how can i fix it?
    thanks,
    Win
    Apr 2001
    Nevada
    anyone?
  7. Member daamon's Avatar
    Melbourne, Oz
    Well, i took the advice given...When i played them back, they were insync!! and the 5.1 tracks were retained.
    I'm glad it worked.
    I imported both into Ulead dvd workshop, and it worked fine. When playing the files in Workshop, it was horribly out of sync
    It may be that either your version or the package as a whole doesn't support AC3 at all, or AC3 5.1 in particular - but what matter if the end product is OK?
    The version of TMPGEnc DVD Author I have doesn't even play any AC3 yet the end product is OK.
    The only problem now is that i have 2 video files. The 1st worked fine, but when trying to import the 2nd ac3 track, ULEAD gives
    an error telling me i have a file format mismatch ... COuld it be that the AVI file is corrupt? and if so, how can i fix it?
    Try running the file through VirtualDub to scan for and then fix bad frames - i.e. delete video and audio.
    I've not done this for a while, so can't clearly remember how to save - obviously you want to preserve the video and audio in their original formats, but save without the bad frames (if that's the problem) in there.
    I can't remember if saving as "Direct Stream Copy" will include the deleted frames. Can someone shed any light on this to help winman42? If it's not the way to go, I'm guessing that saving will have to be done using the correct video and audio codecs, but will that preserve the 5.1 AC3?
    Carpe diem.
    Apr 2001
    Nevada
    OK, again, thanks for the reply. Here is the latest:
    Ulead does support ac3 5.1, so thats not an issue.
    What i did was check both avi files with VirtualDub,
    and they both were fine. So i took the offending ac3 file, and used ac3FIX on it. AC3FIX reported
    that the orignal ac3 file was fine, but it created a
    new file, which when loaded into Ulead worked!
    So i finally got i all to work, so again thanks for
    guys for all the help!!
    Win
  9. Member daamon's Avatar
    Melbourne, Oz
    Hey, no problem. Glad it's sorted... And cheers for posting back - it 'll help any others with the same problem.
    Carpe diem.
