  1. This is my first attempt at ripping a DVD and I can’t seem to get it right.
    Here is what I have done so far :
    I’ve created a VIDEO_TS folder with vob files using both ‘DVD Shrink 3.2’ and ‘DVD Decrypter’.
    I then used DVDTOAVI (compressing as xvid ) and when that failed I tried TMPGEnc DVD Author 1.6.26.73 (with the ac3 plugin) that failed too. The problem I am encountering is that the audio and video are not in sync. Moreover the video seems to be smaller then the audio (timewise). What that means I don’t know. I am using xp with sp2 if that has any bearing. Please help!!!
    Elaphe
  2. Can somebody at least point me in a direction? I mean is the problem with the rip or conversion? Please help I am loosing my mind.
  3. I've been searching and searching for an answer, but I cant find anything. It seems that quite a few people have this problem. Is there a guide that I am missing that addresses this? I've been considering buying one of the retail products that rip to any workable format, but they are expensinve and my fear is that I pay all this money and it still doesn't work. Can somebody give me some kinds guidance? I am a poor college student and paying $50 for a program means I eat pasta and sauce or tuna all week. I don't mind doing that, but I would hate to do that and the program still doesn't work.
    Elaphe3
  4. What format do you want to go to? You say AVI and MPEG in your subject line - which is it?
    If it is MPEG, use TMPGEnc to encode it. If it is AVIm I would recommend AutoGK coupled with DivX or XviD.
    There are plenty of guides over to the left under "Convert" that will take you through this step by step.
    Cobra
  5. I would prefer mpg -2, however anything workable would be fine at this point. I used TMPGEnc Author to convert the vob's and the result was an audio sync problem???
    Elaphe3
  6. Run your original .VOB files through DVD2AVI. Select "Downmix to stereo" and output to WAV. Save the project. This will output a .d2v file (very small) that you can feed into TMPGEnc and a WAV file that also goes right in.
    https://www.videohelp.com/mpeg2tovcd.htm
    This guide says to use .mpa audio - never seen this before from DVD2AVI but I'd still suggest you use WAV audio.
    What is it that you are trying to achieve here anyway?
    Feb 2004
    Australia
    Check my reply here :
    https://www.videohelp.com/forum/viewtopic.php?t=246033
    It fixs 99.9999999% of stuffed up dvds
    What I mean is producers edit menus , vobs and ifo files in various ways so as to prevent people from making pefect legal backups .
    My way may be longer than some , but its done using freeware
    and all my mpeg4 files play with no issues at all , perfect .
