I have 2 Xvid files that I want to join and burn to DVD. They are currently 640x272, 3ivx D4 4.0.4 with 48000Hz, stereo AC3.
I used the join tool in ffmpegX but the audio has come out sounding like a scratched record. The audio and video of the original files is very good so before continuing any further, I thought I would pop in here and get some guidance rather than wasting too much time meandering about not being too sure of the best way to go about all of this.
I did come accross an app called d-vision which joins avi file for Mac, but I haven't looked very closely at it yet ... and the documentation is in French.
I also want it so that it has a normal screen size (resolution?) but I don't want to lose too much quality in this process.
Would appreciate any help from people as to how I can achieve this.
Thanks muchly
imacaroon
I'd use Quicktime Pro (you will need appropriate codecs) and copy n paste.
for divx2dvd i recommend using mpeg2works.
you will should get a very nicely synced mpeg2 file which you can then author with sizzle -
Aye. Used Quicktime to join, then Mpeg2 Works and dropped the m2v and mp2 files on Toast to burn to DVD and it came out just great
thanks all
imacaroon
How to join back 2 xvid files encode by autogk
By warresg in forum DVD RippingReplies: 1Last Post: 6th Nov 2010, 02:59 -
Join Avi (xvid) files together
By SpyJoe in forum EditingReplies: 11Last Post: 26th Aug 2009, 17:44 -
Xvid messes up when widescreen
By crt in forum Video ConversionReplies: 1Last Post: 4th Nov 2008, 06:11 -
I Can't Join 2 XviD Videos together!
By Nitro89 in forum EditingReplies: 10Last Post: 26th Jun 2007, 15:08 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
