I am trying to encode my Fuji Finepix 5100 movie/avi (mjpeg) files that are 640x480 @ 30fps to DVD template in CCE and even with the dvd template loaded (29.97fps/720x480,384bitrate 48K audio) the output ends up scewed to the left cutting off a large portion of the screen. In short, it's not making the transition properly from 640x480 to 720x480 AND dvd authoring software gives additional error that 30fps not valid dvd frame rate. Why is CCE not converting and re-encoding these avis correctly? I've used CCE extensively and never run into this until I bought this new digital camera and tried to convert the avi's. I have CCE 2.67 SP and use EclCCE to load.
Mike
You should convert to 352x480 or to 704x480. Both are valid DVD resolutions.
PAL DVD to NTSC DVD: CCE is changing resolution (720x480 to 720x576). Argh.
By Colmino in forum Video ConversionReplies: 2Last Post: 9th Jan 2009, 20:15 -
VHS to DVD resize 640x480 or 720x480
By opti280 in forum Authoring (DVD)Replies: 2Last Post: 26th Feb 2008, 19:43 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 06:50 -
How to convert 640x480 to 720x480 ?
By webstar in forum MacReplies: 3Last Post: 8th Jan 2008, 10:44 -
hauppuage 720x480 best conversion for web
By jwfc in forum Newbie / General discussionsReplies: 3Last Post: 8th Jul 2007, 22:37
