Hi,
What software would I use to break a movie file up into parhaps several movie files to use as chapters? Preferably free?
Bizt
Are you talking about a DVD ? What authoring software do you use ? Usually a movie isn't split into seperate pieces to create chapters, as this can result in a pause between the pieces. Your authoring software should allow you to mark the chapter points without having to resort to this.
Read my blog here.
There are several good editting programs for cutting and joining. For avi files virtualdub is free.Originally Posted by bizt_uk"Art is making something out of nothing and selling it." - Frank Zappa
Hi,
Im using DVD Author. I havent used anything else and just assumed that was how you done it.
Whats a good recommendation of DVD Authoring software for a newbie, not too complex but good useability and quality? Also, I would like something that I could add subtitles to movies as a menu option too?
Bizt -
Here's a guide for TMPGEnc DVD Author, you can set your own chapters or do it at regular intervals.Originally Posted by bizt_uk
I use TDA and I think it's newbie friendly, I don't think it supports Subs though."Art is making something out of nothing and selling it." - Frank Zappa
Best method for splitting up an .avi into various chapters and burning
By aple in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2011, 21:24 -
Splitting TS-file with tsMuxer creates lag in end file
By Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 17:44 -
Read chapters from a file to use them in mkvmerge as splitting-timecodes
By bastik in forum User guidesReplies: 1Last Post: 24th Jul 2010, 13:12 -
Splitting a Movie into two parts
By mysts in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2008, 23:25 -
VOB editing before burning (splitting, chapters, etc)
By windranger in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2007, 09:29
