Hi!
I have an AVI file with AC3 in NTSC (29.97) that I have converted to MPG2 the video with TMGenc and I have extracted audio from the AVI file with virtualdubmod. To author I use DVD Lab after authoring the video result without audio. The strange thing is that looking on the assets the video time is 1:32:26 and the audio is AC3 1 channeldolby 1.0 192 kbps ratio and the time is 1:32:31
May that different time between audio and video that can create problem or not? How can I adjust this problem?
Thanks in advance
haltman
It's one of the quirks with DVD Lab. The audio duration shown is correct. The video duration shown in the assets list is the timecode for the start of the last GOP. It is a bit disconcerting at first, but you get used to it. If the durations are within a few seconds (as they are in your case), it should be OK. I don't know if Oscar intends to fix this or not.
I second what guns1inger said; I've noticed the same thing, but I've found that this never causes any problems during playback.
6 WAV files to one 5.1 AC3... need more help please..
By RogerTango in forum EditingReplies: 17Last Post: 13th Oct 2012, 08:00 -
Join AC3 files
By rgraiche in forum AudioReplies: 8Last Post: 20th Aug 2011, 15:56 -
How to create M4V files w/AC3+AAC from M4V w/AC3 only??
By williamlondon in forum MacReplies: 4Last Post: 5th Oct 2010, 16:15 -
AC3 (5.1 audio files) and PCM 96/24bit stereo audio files
By joannes in forum Authoring (DVD)Replies: 2Last Post: 9th Mar 2010, 15:48 -
AC3 Files with TMPGenc
By PHNeedsHelp in forum AudioReplies: 3Last Post: 4th Nov 2009, 12:37
