I've been using SmartRipper for dvd backup purposes for about 2 yrs now without any problems until now. My problem is this:- it rips the ifo, idx and bup files fine, but the vob files come out as 0kb in size! Anyone shed any light on this pls? I've started to use DVDDecrypter and this works OK but I prefer to use SmartRipper as there are more options.
Thx
Smartripper has ceased on development years ago and DVD Decrypter is active and still improving. If you had a problem with SR, who's going to fix the bug? Besides, Smartripper's feature option to decrypt/rip from HD, how can you possibly say it has "more" options. Though you are using a old tool, it still work. But, in the long run...you'll be coming around to accept your fate with DVD Decrypter. Most or if not all high rollers in the backup community use it with success. Why not jump on the bandwagon and come to the other side of the fence where the grass is greener.Originally Posted by Cityfan2004
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 19:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 21:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 15:26 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39
