  1. i basically have dvd's and i want to cut out scences and make them ram
    so some people can see and have the option to resize
    here is an example
    someone took this out of a dvd and made it ram and resized it
    http://ww.smashits.com/video/player/v_rvplayer.cfm?ImgShown=1&videolist=d_video/msk/song4-f.rm,4083
    i want out to know the exact steps to do that
    thanks a lot
    simple
    you can convert and cut to avi/divx/xvid using fairuse 0.9.3 or dvdx or virtualdub-mpeg2 and then convert to rm using helix producer or some other rm converter(click on tools and select to Rm under conversion).
    advanced
    or frameserve from dvd2avi or DGMPGDec or virtualdub-mpeg2 to helix producer...maybe you need to use vfapi reader to be able to open the frameserver file.
  3. is there any specific easy to use helix software?
    i dont like realproducer thats why
  4. hey admin
    i used dvdshrink and got a very small vob and i am happy
    now for the next step what can i do
    to make it ram/rm and change the resolution
    with a program can u give me a specific program
    and if possible the same but request but this time wmv
    thanks
