Can somebody please help.
I'm trying to convert a 700mb AVI file in FFMPEGX to output as VIDEO_TS so I can Toast it. The problem I keep having is that when the coversion is complete the files don;t seem big enough.
If I use the preset 'DVD-ffmpeg' and the info in the bitrate calculator looks ok. DVD, 4000mb etc and in post processing I check the 'output as _TS' box but after about an hour I get about 5 different files outside the _TS folder amounting to no more than 500mb.
What am i doing wrong? Any help will be greatly appreciated.
This is an authoring problem. Demux the MPG file and remux it "as DVD" and reauthor it "as DVD". All these tools are available in the Tools tab.
ffmpeg engine is still subject to DVD authoring problems, though usually demuxing and remuxing solves them.
Could my problem be that I don't have mpeg2enc installed? I thought if I encoded through mencoder I wouldn't need it.
Does anybody know where I can find a step by step guide for converting AVI to Video_TS as I've got no idea what i'm doing and what encoder to use.
Any help is appreciated.
You can adapt this guide http://homepage.mac.com/major4/divx_svcd.html by selecting the DVD quick preset instead of SVCD quick preset.
Thanks for that.
Should I use the DVD-(mpeg2enc) or DVD-(ffmpeg)? Is there any difference?
Thanks again
AVI.NET newb :-o
By kr236rk in forum Video ConversionReplies: 3Last Post: 29th Feb 2012, 07:10 -
What's the difference between _TS and .ts files?
By Yellow Peril in forum Video ConversionReplies: 3Last Post: 1st Apr 2011, 05:16 -
New newb with old question
By Madzir55 in forum RestorationReplies: 4Last Post: 17th Jan 2010, 13:05 -
Skipped or Duplicated Frames - .mov to *_TS using FFMPEGX
By oppus in forum Authoring (DVD)Replies: 4Last Post: 2nd Oct 2007, 09:13 -
Hi NewB here with some serious problems..
By *Equilibrium* in forum Software PlayingReplies: 3Last Post: 30th May 2007, 10:22
