Hello,
I'm trying to make an xmas video and want to include some
old pics that will have to be scanned. My question is, what is
the best setting to use to scan with so they work with DVD.
What resolution do I use when scanning, and do they need
be a certain size to work with DVD video. I use video studio
8 at this time. I would also like to thank everyone on this
board for all the help I've have had so far by just spending
an hour or so every night reading, you people are great.
Zen
if you want them to be full screen, scanning them at 150-200 dpi should give you enough detail for your project.
if you want to do a lot of panning, zooming and "Ken Burns" style stuff, scanning at a higher resolution is important so you don't lose detail.
I did a project recently where I only had photos to work with, and I did a lot of panning and zooming. I scanned all the photos at 600dpi and it worked quite well - I was able to zoom in quite severely and not pixellate or lose detail.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Thank you for the info housepig. If I scan a 4x6 pic
will it fill the whole screen like the dvd or does is it
need to be resized?
Zen -
well, 720 dpi / 6" wide = 120 dpi minimum.
- housepig
Housepig Records
out now:
I seem to remember an aspect ratio issue when scanned pics are authored to DVD. Try this test: create a perfect circle (about 4 to 6 inches across) in a paint program, and print it.
Scan it and author it to an RW DVD, then look at it on a TV and see if it's still a perfect circle.I don't have a bad attitude...
Life has a bad attitude!
Scanned 16mm Optical Soundtrack Direct to Digital Audio?
By mtt1853 in forum AudioReplies: 29Last Post: 16th May 2013, 01:14 -
AVCHD - 1080p MP4 file to BR Format works - looks panned & scanned on TV
By hankhandsome in forum Authoring (Blu-ray)Replies: 7Last Post: 6th Mar 2012, 21:50 -
PLEASE HELP - Getting scanned photos off of a Video...
By violet in forum Newbie / General discussionsReplies: 6Last Post: 19th Jul 2010, 12:09 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 12:49
