1. Does DVCAM have the same format as mini-DV so that I can plug a firewire into my PC and transfer the digital video?
2. If I convert PAL 720 x 576 video to NTSC 720 x 480, presumable I will be resampling the height of the frame, and although the storage aspect ratio will change, the display aspect ratio will still be the correct 4:3 and appear at the correct size.
3. Although frames can be inserted to bring PAL 25fps up to NTSC 30fps (29.97fps), presumably "better" software will interpolate the missing frames?
Regards,
Ian Tresman
Derby, UK
Originally Posted by iantresman -
Originally Posted by bugster
Ian -
To you have any words of wisdom for converting PAL DV to NTSC, that will ensure that hightest possible quality (other than high bitrates). I'm transfering an art film.
Regards,
Ian -
You can use these programs to convert interlaced PAL to interlaced NTSC with very good results:
Sony Vegas.
I assume the much cheaper Vegas Movie Studio can do it as well, but I haven't tried it.
Canopus ProCoder (or its little brother ProCoder Express).
Avisynth (free, but not user-friendly).
I'm sure there are a few other options, but Vegas, ProCoder and Avisynth are the ones I have tried. -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Hi8 NTSC to DV/DVCAM PAL conversion
By cc2010 in forum Video ConversionReplies: 1Last Post: 29th Apr 2010, 04:04 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
